noisy tranny
Old Jul 25, 2003 | 01:23 AM
Zerosheaven's Avatar
noisy tranny
i changed my tranny fluid from god knows what (bought it used) to mobil 1 syn. afterwords my tranny started to sound realy noising during exceleration and stuff. is that normal because of the switch or do i need to add more fluid??
you think i should stop driving it in the meantime or have i aleady damaged something?
Old Jul 25, 2003 | 04:10 PM
MikeTR's Avatar
Is it an auto or an M6? I switched to synthetic in my old M6 & it was louder then before so I switched back to regular & it was quiter. If it's an auto, you may have issues.
Old Jul 25, 2003 | 05:04 PM
M6
yea its much noiser, i even notice noise while driving.
do you think its going to be an issue where something might get messd up or you think its just noise and nothing more?
Old Jul 25, 2003 | 05:06 PM
rpm4lalo's Avatar
My T56 did not become louder when I switched to Mobil 1 Syn ATF.
Old Jul 25, 2003 | 08:02 PM
MentalCaseOne's Avatar
Sooo lets see You Manual transmission did not get louder when you switched to mobil 1 ATF?? as in Automatic transmission Fluid??
I have an auto.. I wonder if I do the switch
Old Jul 26, 2003 | 02:02 AM
hmmm.. i think the noise just comes with the change or something
coz power feels fine shifting feels fine , everthing seems ok except for the noise....duno i guess its normal..only time will tell
Old Jul 26, 2003 | 03:05 AM
94 TA TT2S's Avatar
MentalCaseOne
Do not change your fluid....you will end up in less than a year at most rebuilding if you do so....I am finding out the hard way....Just a lil heads up....Ask around and they will tell you if you don't believe me....I am gonna have to get mine rebuilt now that I changed the fluids , they say with removing all the particles in the tranny actually hurts when you go to fresh fluids,allows it to slip too much and then causes excessive wear....Its crazy but trust me......
Old Jul 26, 2003 | 04:35 AM
scoobysnax83's Avatar
Re: MentalCaseOne
Dude...he has an M6. Do people no longer read posts?
Old Jul 26, 2003 | 10:24 AM
94 TA TT2S's Avatar
I have noticed that as well...
Old Jul 26, 2003 | 11:21 PM
94ta what you didnt noticed is that I was replying to a guy who states he did put ATF on his Manual transmission...
what I forgot to say in my post was... I wonder if I do the switch too.. meaning using gear oil in my Auto tranny.
Now unless the Manual Tranny uses ATF ... something is wrong with that guy.... (or whatever autoparts Jockey who sold him the fluid)
Marvin
Old Jul 26, 2003 | 11:52 PM
White96Z's Avatar
Marvin
Both the five and six-speed manual transmissions use dexron II ATF tranny fluid instead of gear lubrication.
Old Jul 28, 2003 | 05:42 AM
They didn't have Dexron III when these tranny's were built therefore the sticker says Dexron II, but Dexron III is perfectly fine in our Trannys.....
Old Jul 28, 2003 | 03:22 PM
dynomight's Avatar
Marvin
Marvin, you need to do some research before making annoying comments. t56 trannies use atf, not gear fluid. I think we noticed what you wrote, but its irrelavent because of misinformation.
Old Jul 28, 2003 | 03:59 PM
turbo_Z's Avatar
is it noise coming up from the shifter or what? my pro 5.0 makes a sucking sound that drives me crazy but i dont think it has anything to do with changing fluids... i just changed from that Honda ATF to the Mobil 1 and notice no difference.
Old Jul 29, 2003 | 07:37 PM
White96Z's Avatar
I figured, but good to know!
