noisy injectors or bad lifter?
i have a ticking coming from my engine compartment......seems a little louder on driver side than passenger side. is this normal? i hear that all LT1's injectors are noisy. i cant hear it from inside the car unless im real close up against a building or something like a drive thru or if i have the hood opened.
Well let me just say...now that I have experience with a loose pushrod(sounds the same as broken lifter i guess)...it is a very loud ticking noise. You can hear it easily from inside the car over the engine and exhaust. It will ofcourse speed up when you give it more gas, cause the engine speeds up. I hope you dont have the same problem as me. Take off the valve cover and check to make sure everythings tight just in case. Its only 4 screws.
If you can still drive it and its fine, then it hasnt come off completly, but can still be loose. You will tell if it comes off, car runs like complete shi!t....very very shaky and loss of power, feels like its gonna cut off.
but from what I hear it can also be an injector or exhaust leak. Good luck, hope its not what happened to me.
http://web.camaross.com/forums/showt...64#post1257364
thanks. i know what a lifter sounds like......sometimes in the winter after the car has been sitting for 2 days, it is loud like that and goes away after a minute. this is not the same ticking i dont think
1996LT1Z28
Apr 14, 2015 07:15 PM
