How to measure pinion angle?
Old Jul 30, 2003 | 01:24 AM
96z's Avatar
96z
How exactly do you measure pinion angle of the TA? A degree or two either way seems like an extremely tight tolerance!
Old Jul 30, 2003 | 01:50 AM
kevmor99's Avatar
When I did my LT1 swap, I placed a degree measuring tool w/ a level on top of the intake, and did the same to the top of the differential yoke. I think as long as they're as close as possible it should be good. Some people suggest even setting the rearend a little off for it to be aligned when under a certain load. You don't want it straight though.
Old Aug 22, 2003 | 12:00 AM
CBalke's Avatar
To find the pinion angle
It's been a while but if I remember correctly you take your magnetic angle finder and you put it on the flat part where the TA
mounts. Then you take the angle finder and put it on the drive shaft. You then that amount of angle from the drive shaft and minus the amount from the reading that was taken from the TA mount. That number should be your pinion angle.
Hope that helps.
Later Colin
Old Aug 22, 2003 | 12:21 AM
LPEdave's Avatar
Here's a writeup: http://www.go-fast.org/z28/pinionangle.html
Dave
Old Aug 22, 2003 | 01:39 PM
CBalke's Avatar
Thanks Dave that is a better writeup with some pics.
Colin
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
heus
Sep 8, 2015 12:01 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Aug 7, 2015 01:26 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
