noise when I turn off headlights.....
Old Jul 8, 2004 | 05:00 PM
Kurt Crosbie's Avatar
When they fold down I get a really bad noise probably coming from the motors. I few weeks ago, I noticed that my right headlight did not come up when I turned on my lights. My idiot friend went under the hood and played with the **** beside the headlight assembly and now it works, but it makes a godawful noise when I turn the headlights down.
Old Jul 8, 2004 | 05:11 PM
Andrew04ME's Avatar
Mine just started doing the same thing. It goes on for about 5 seconds after the lights go down. I'm curious as well...
Old Jul 8, 2004 | 05:23 PM
Kataklysm's Avatar
You need a new headlight gear. On ebay you can buy a brass one for $30-40 so it won't strip out again.
Old Jul 8, 2004 | 06:00 PM
ucnu112's Avatar
you can also disconnect the lever, turn the gear 180 degrees and reconnect it. You'll then be using the other side of the gear that should still be new. There are a few write-ups floating around here that tell you specifically how to do it.
Fred
Old Jul 8, 2004 | 06:01 PM
LT1Squirrel's Avatar
you could also try Brent's headlight fixhttp://www.bfranker.badz28.com/headlightfix/index.htm
Old Jul 8, 2004 | 06:03 PM
ucnu112's Avatar
yep, that's the one I was looking for:
Free Gear Fix
Fred
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
formula79
26
Aug 5, 2002 12:21 PM
