Is this noise piston slap?
Old Jun 19, 2007 | 08:43 AM
wrd1972's Avatar
When I start my engine up I get a rubbing or scuffing noise which can be heard inside with the windows up. Under the hood it can be heard around the valve covers but this does not sound like rockers to me since it is NOT a ticking or knocking sound.
This sound is not very loud at all and can not be heard when the engine revs above idle. The noise goes away in about 5 minutes once things warm up.
I have forged .030" Mahle pistons which some say may create piston slap.
Does this sound like piston slap to you guys?
Old Jun 19, 2007 | 10:55 AM
arcticz28the383's Avatar
I also have some piston slap with SRP forged pistons. Just don't beat on it right away you should be ok as long as it doesnt get louder. Many vehicles have piston slap, even new ones.
Old Jun 20, 2007 | 07:12 PM
wrd1972's Avatar
So your makes this exact same scuffing sound I am describing?
Old Jun 20, 2007 | 08:46 PM
mobleman's Avatar
Possibly timing chain rubbing on the front cover, which goes away as the cover heats up? (aluminum expands quicker than steel with temp)
Or maybe rubbing between cam retainer plate and cam timing sprocket? (Think mine does this a bit, results in a rubbing noise was getting better with time)
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
