Noise with the clutch in
Old Apr 14, 2003 | 09:35 PM
fbird95's Avatar
When i first start the car in the morning, i put the clutch in and start it up, If i put the clutch in after that it makes this funny buzzing noise that goes away when i shift it into gear while in park or rev the engine. When the car is warmed up i dont have this problem. Any ideas. The clutch still grabs like a champ with no slipping.
Old Apr 16, 2003 | 01:24 PM
fbird95's Avatar
Somebody must know
Any help is greatly appreciated.
Old Apr 16, 2003 | 04:14 PM
JETMAN95Z28's Avatar
usually a noise associated when the clutch pedal engaged is the throw-out bearing. Usually they SQUEEL real loud when you have a bad throw-out bearing but yours could be just starting to go south. It's my best guess. They don't cost much but it's kind of a pain to change since you have to drop the U-joint, and pull the transmission to get to it. Ughhh!
UNLESS
Shobox or someone else here has a short cut technique????
Old Apr 18, 2003 | 10:01 AM
fbird95's Avatar
I cant figure out why it only does it sometimes, and when the cars cold.
Old Apr 18, 2003 | 02:13 PM
ur2slow's Avatar
The same thing happens with my car. I took it to the dealership and they couldn't get the noise to happen. It only happens when it is cold after sitting for a long time. I've come to the conclusion that it is the throw out bearing.
What will happen if you continue to drive the car in this condition. Will it eventually just fail or cause a lot more damage to the trans?
Old May 4, 2003 | 10:35 PM
fbird95's Avatar
From what i understand, from the guy at the trans shop, it was my pressure plate that was starting to solapse in on itself causing this noise.
Old May 4, 2003 | 11:00 PM
camaro6's Avatar
Thats probably it
Ericksd
Jan 20, 2016 06:07 PM
autoxr166
Sep 25, 2015 04:21 PM
Ericksd
Sep 16, 2015 07:08 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
rideordie
Sep 7, 2015 08:22 AM
