Noise after i let off the clutch?
Old Jul 1, 2003 | 08:10 PM
drewstealth's Avatar
Sometimes when i'm shifting through the gears and i let the clutch out i can here a noise. I can sort of feel it also. So for instance when i shift from 1st to 2nd right when i let the clutch all the way out it makes like a little bang noise that i can slightly feel. It does it often from 2nd to 3rd. It does it in other gears but not as often. What do you think it could be? Also my tranny makes a lot of noises while the clutch is out. Although i everybody says these transmissions make a lot of noises anyways. The car does shift fine though.
Old Jul 1, 2003 | 08:40 PM
RCF925's Avatar
Check your rear tranny mount
Old Jul 4, 2003 | 03:26 AM
I have a Energy suspension tranny mount.
Old Jul 5, 2003 | 02:15 AM
cals400ex's Avatar
i would say that with an ES tranny mount and a pro 5.0 that your tranny will make a decent amount of noise. after i installed the pro 5.0, mine was quite a bit noisier. i used a thick rubber gasket between the shifter and the tranny and i now have less vibration than with the factory shifter. that gasket must of helped big time. its still noisier though.
Old Jul 5, 2003 | 06:05 AM
sideways_Into_3rd's Avatar
its ur pilot bearing
do u also hear it when the cars ideling with clutch out ?!
not a biggie .. just change ur pilot bearing when u do ur clutch
Old Jul 5, 2003 | 09:06 PM
Yes it does make noises when the clutch is out at idle. But i just put in a new needle bearing. When i installed my slp clutch which is about 2,000 miles ago.
Ericksd
Jan 20, 2016 06:07 PM
autoxr166
Sep 25, 2015 04:21 PM
Ericksd
Sep 16, 2015 07:08 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
rideordie
Sep 7, 2015 08:22 AM
