No whine/noise from gear drive install, should I be worried?
Old Apr 8, 2004 | 06:11 AM
LT1RX7's Avatar
I just started my car from a major install which included a Pete Jackson gear drive kit. When I started the car the exhaust was loud but I did not hear any whine at all from the gear drive set. This is a good thing for me but now wondering if something will go wrong. The car turned on and idled so I'm guessing it should be good. Still no whine from a gear drive, that's strange isn't it?
Old Apr 8, 2004 | 06:25 AM
Newbie97's Avatar
How did you install a gear drive on a LT1. Thats impossible.
Old Apr 8, 2004 | 06:47 AM
LT1RX7's Avatar
impossible? First hand experience here, it's possible.
Old Apr 8, 2004 | 08:12 AM
importeater's Avatar
Please inlighten us as to where you got the gear drive for an LT1! I have been searching everywhere and everyone says they dont make them.
Old Apr 8, 2004 | 08:16 AM
Eliminator's Avatar
I also would like to know where cause I heard that the knock sensors will pick it up and make the car run like crap.
Old Apr 8, 2004 | 08:39 AM
meandmyz's Avatar
im pretty sure if you use an electric water pump you can use the gear drive.
Old Apr 8, 2004 | 09:04 AM
I was thinking that too but will it still work with the opti?
Old Apr 8, 2004 | 09:24 AM
DarkHorse's Avatar
I'd love to hear this one too.
What brand?
EDIT: Pete Jackson. Is this a 93 + LT1 or the old LT-1?
Old Apr 8, 2004 | 09:48 AM
97FormulaWS-6's Avatar
U can use one... U have to machine the timing cover to accept the idler gears. Someone on this board has been running one for atleast 3 years now...
You have to dis-able your knock sensor, use a Electric waterpump, modify the timing cover, and on 96/97 cars remove the CPS (crank position sensor).
The only hard part is maching the clearences in the cover. The easiest way is to install the gears, mark the shafts with some marking compound and install the cover the best you can. The marking compound will mark the cover where you need to machine in reliefs for the gearshafts.
This is one mod I'm doing when I put a cam in my car.
Old Apr 8, 2004 | 07:42 PM
LT1RX7's Avatar
The gear drive I got is for sbc's up till 95 w/o hydrualic cam. It was a simple install. I just had to clearance the cam cover like 97FormulaWS-6 said and use an electric waterpump. The knock sensor I'm still not sure yet, from the way it sounds I think I'll be fine. If it does trip the sensor too much than I'll just eliminate it
HectorM52
Jul 30, 2017 11:46 AM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Elcojoe
Nov 17, 2014 10:27 PM
