no voltage going to ign module
Old Sep 23, 2007 | 03:18 PM
mdacton's Avatar
everything checks good coil, new wires, plugs etc.
I have no voltage going to my module, what do I check next? Is it a possible pcm problem
Old Sep 23, 2007 | 03:33 PM
How about the ignition fuse? It feeds the pink wire to the coil and the ICM.
Old Sep 23, 2007 | 03:48 PM
mdacton's Avatar
fuse has power going in and out......, I have power to my pink coil wire
Old Sep 23, 2007 | 04:19 PM
Better scope out the wiring harness, then.
Old Sep 23, 2007 | 04:36 PM
mdacton's Avatar
pplugged another opti to it, now I have voltage to terminals 1 and 3 so something in the otpi is bad, also has spark when I spin it. I guess something on the low resolution side? Also now the air pump cuts on so thats what i'm guessing.
Let me go put this on and see what happens. Thanks
Old Sep 23, 2007 | 05:39 PM
mdacton's Avatar
I just got the opti on, started it and it knocking like a MF......oh well. Pull the motor out now
junk lt1's
Old Sep 23, 2007 | 10:43 PM
doug1105's Avatar
I'm in the same slow boat.
I just put a new coil metripack pigtail on the harness today.
I had voltage on the pink but not the green.
I found out the green was broken inside the plug by only accident.
I left the multitester on the ignition module green and bumped the coil plug and the voltage went to 0. Bump again and voltage comes back.
Serious pita LT1.
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
RUNMYTA
Jul 15, 2015 07:50 PM
