No start, quick question... Makes logical sense.
swapped starter. Wow, what a powerful starter... However, it still does not fire. I checked from ground to a spark plug wire with a meter and I didnt get any voltage.
So I guess I am going to see if I can check for CEL's and see what might be causing the problem.
huh?
Dave89Iroc: Is there a better method? I would assume if there was spark the meter would read the voltage?
Ok, so I took a look at my manual and tried to follow the toubleshooting steps for the coil... However, I am having a weird problem.
I get 12v constant with the key in the on position on the harness that plugs into the ICM. Better known as "B" in the diagram. So this looks good. However, I was just curious, thinking I might have a short... And when I go from ground to "B", "D", or "C" I get continuity... Is this normal?
I do not get the 10v like is says I am supposed to on either A or D.
The ignition fuse was blown. I put in a new fuse, cranked it over and BAM! The loudest backfire I have ever heard in my life. I think I am deaf. So I am guessing my opti took a crap... This thing has bearly any miles on it... Less than 5k.
I didn't cross plug wires. I contacted Jason Cromer today and he said they would not warantee the opti. I guess they do it by yearly, not mileage. I think thats a horrible business practice personally, but I am not going to get into a big huge sob story about my 5 thousand mile opti. I will just eat the distributor and go with msd since they stand by their product.
Just incase anyone wants to know... Its an 8mm but with 1.25 thread pitch. I got the car working. It sounds like the bearings on the alternator are on their way out though.
Glad to have it working again.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
guionM
14
Jun 19, 2002 08:30 AM
