No Start problem
Old Mar 4, 2006 | 07:51 PM
  #16
mike 96 ws6's Avatar
Re: No Start problem
Originally Posted by FastZinTennessee
I don't know for sure- it's possible that the ICM could be bad, but still work sometimes. I suggested the Autozone test because it's the only way I know of to rule it out completely. Trust me, I just went through a whole s***load of ignition troubleshooting, and if there's one thing I've learned it's this- you have to be methodical about testing components, and you can't move on to testing another component until you know 100% that the one you've just tested is working correctly.
Agreed! An excellent approach that will certainly save money in the end and likely time also, although it doesn't seem like it sometimes while you are following that method of troubleshooting. Good advice.
Old Mar 4, 2006 | 08:26 PM
  #17
Shon Herron's Avatar
I will take the ICM in to be tested.
I did not get spark from the wire to header but wasn;t sure if I had the terminal close enough for it to jump to the header and I could not stick a screw driver close enough to get zapped, had the wife turning the ignition key and she might have enjoyed that too much and just kept cranking till the battery died, or me, LOL.
I was under the impression that if the coil was firing the ICM was good. But let me know if this is not the right impression.
Thanks for the discussion!!!
Old Mar 4, 2006 | 08:57 PM
  #18
LOL
If AZ can test the ICM for free, it would be be a way to rule out that part as being bad. As FastZinTennessee suggested, that would be a wise step to take before spending any $ on other parts.
If you have no voltage to the plug wire but do have voltage to the opti coil terminal, that would suggest a problem in the distributor, the electrical circuit supporting the distributor or the drive from the cam to it.
turbo_Z may have it nailed, but don't go tearing into it and spending $ till you rule out the simple stuff. I'd check continuity on the wires on either side of that opti connector too since that has caused problems for several opti buyers who had a good opti originally.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
