No start Diags
Old Dec 15, 2009 | 06:01 PM
Mir Hussain's Avatar
Exclamation No start Diags
I am sure this topic has been beaten death linke there is no tomrrow
Now, my stitution may be little different.
I have the car parked for 1 1/2 year. At that time I I fill the gas 3/4 full and took the battery out.
Today I cange the oil and oil filter. Put the New Battery. Start the car up It starts up fine drove around the block for a 1 min. Then I parked the car.
This evening I wanted to take car to emission shop, so I try start car, and pulled out from my parking spot, then car died!
After few tries, I gave up so I push the car back to my spot.
Then after few mins I try to start the car again, it didn't at first few times.
Then finally it started. I let it run for a minute. Then I gave little gas it rev up then died again.
I tried again but no go.
Engine will get crank but wont start.
Where do I start from ?
Old Dec 15, 2009 | 06:19 PM
bw_hunter's Avatar
Pull one of the plugs and take a look...you might have some gummed up fuel since it was sitting so long.
Old Dec 15, 2009 | 10:42 PM
Question
Now what is the socket size to open a Spark plug (sorry it is been long time)
If plug is fowled wouldn't it just cough and startup ?
Old Dec 16, 2009 | 08:47 AM
pizzi-man's Avatar
Check that you are getting good spark to the spark plugs. Had the same thing happen to me after having the car sit at the body shop for 6 months. The book says that a weak spark is like a no spark. could be your cap and rotor with oxidation on the contacts.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
