No start after Cam install...need help
Old May 26, 2008 | 02:13 PM
Peckaldee's Avatar
Finished a cc306 cam install with ported heads, all new valve train(except valves), extreme duty timing set, new injectors, longtube headers. Tune is from Madz28.
The car started after about 5 or 6 tries. Then it would surge badly and not run unless you manipulated the throttle. Let it run for about 5 minutes and let it die. Showing no fuel pressure from fuel rail. Tried starting again and would not fire. Changed fuel filter. Still no pressure. Fuel pump is priming when key is turned. Haven't looked at the plugs yet.
I have a Datamaster file from one of the failed starts if anyone can take a look at it.
Any help would be appreciated.
Thanx
Old May 26, 2008 | 03:20 PM
Pontiac_97's Avatar
are you getting pressure when the pump is priming?
Old May 26, 2008 | 07:28 PM
Peckaldee's Avatar
absolutely no pressure at all from the gauge i'm using. Still need to find out if the guage is working. It's fairly new and has only been used once before the tear down to check existing fuel pressure.
Old May 26, 2008 | 07:40 PM
joeSS97's Avatar
Try pushing the shrader valve in on the rail wit a pen or something small,if it does'nt squirt,no pressure.Prolly the pump. You need to check the basics,spark and fuel.And it sounds like you have a fuel issue.
Old May 26, 2008 | 07:59 PM
Peckaldee's Avatar
I am assuming that it is fuel related also. There is some fuel coming out of the valve but I still havent been able to read any pressure. I still haven't checked to see if the gauge is bad. This next week I should get time to check plugs. With it running for a few minutes and surging very badly, I feel it is most definitely fuel.
I still would like someone to check out this datamaster file of the failed crank to see if they can decifer any bad sensor readings.
Old May 27, 2008 | 01:25 AM
JP2005's Avatar
forget the gauge, if youre not sure if its working...spray some starting fluid in the intake, if it fires up from then its fuel related
Old May 28, 2008 | 04:34 PM
Peckaldee's Avatar
can anyone else offer some advice? The spark plugs look good. Pump sounds strong when it primes.
Could this be caused by bad gas?
Old May 28, 2008 | 05:10 PM
JP2005's Avatar
when you spray starting fluid in it does it start up and run fine for a few seconds? if yes, it is probable bad fuel.
Old May 28, 2008 | 05:16 PM
Peckaldee's Avatar
haven't tried starting fluid yet but I will this weekend, still trying to get some more info though thanx for your help
Old May 28, 2008 | 11:08 PM
ACE1252's Avatar
Doesn't mean jack. You need to get a good pressure reading off the rail.
Do the basics....spark, air, fuel, opti-spark wiring....I'm assuming that the cam was installed correctly(timing marks, etc).
Old Jun 1, 2008 | 09:51 AM
Peckaldee's Avatar
Well here's an update....
Finally got the gauge to show fuel pressure. After siphoning tank and adding about 5 gallons of new gas. Sitting right at 39 psi. Push it outta the garage and try to fire it up. No spark. Started checking coil and opti. Nothing. Finally thought about the fuse. Yep, it's the ignition fuse. Changed it out and now it runs fine. Madz28's tune is fantastic! No surge, great idle.
Thanx for your help guys. I was about ready to pull my hair out.
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
