No Spark issue (98 V6 to LT1 Swap)
Old Sep 28, 2004 | 12:03 AM
pgriffith's Avatar
I did a LT1 swap in my 98 camaro. I cant get it to start. The injectors are pulsing and the fuel pump turns on. I have fuel pressure. Very odd though it seems to make a weird noise coming from the fuel rail. Is this normal with LT1's? And the fuel pump stays on, it wines pretty loud. But i am getting fuel pressure and the injectors are pulsing, i tested them with a multi-meter. But i am not getting spark to the coil. I replaced the coil and it ddidnt help. I then checked further and there is no power going to the coil itself so no spark coming from the coil as well. Is there something i can check? maybe something i overlooked in the v6 to LT1 swap? Its a 94LT1 with OBD2 PCM and knock sensors. I had the same problem trying to start with the OBD1 pcm if it makes a difference. Please help
Old Sep 28, 2004 | 12:07 AM
jdizzell's Avatar
Re: No Spark issue (98 V6 to LT1 Swap)
I would go back to the orginal pcm, because obd2 uses more senors then obd1. How long does your fuel pump stay on?
Old Sep 28, 2004 | 12:09 AM
Check the IGN fuse.
jdizzell's Avatar
Oh yea, obd2 uses a crank postioning sensor that is used on start up. 94 LT1 does not have one.
Old Sep 28, 2004 | 12:32 AM
pgriffith's Avatar
Forgot to mention, Madz28.com had reprogrammed my pcm to work with these differences. Crank position sensor, O2 sensor etc... It has all been reprogrammed to work.
The fuel pump stays on forever. If the Key is in the on position the fuel pump stays on... RRRRR>>>>>>>>>>>>> Its the sound i am used to hearing but then shuts off after 1 or 2 seconds. But now its on all the time.
Old Sep 28, 2004 | 08:00 AM
The crank position sensor has nothing to do with spark delivery on an LT1. It can be totally broken, disconnected or removed and the engine will run just the same. It is only there for misfire detection.
Old Sep 28, 2004 | 09:05 AM
WS Sick's Avatar
If the ign circuit is open to the Opti the fuel pump will not even kick on, I think you have two seperate problems, check your grounds, should be a strap and pcm grounds on the front of the drivers side of the block (just below the ign module and on one of the bolts that hold the ign mdl down, also check out your grounds on the pass side of the black , a lug about midway down the block has two wire crimped onto the same lug. If the grounds are good check your ign module and its wiring.
Oh forgot to add, Shoeboxs site has pictures of all this for reference as well (thanks again for the site Shoebox)
Old Sep 28, 2004 | 11:21 AM
tryintogofast's Avatar
The fuel pump should turn off after a few secs. I'd check to make sure you don't have any leaks and then check your fuel pressure aswell. I don't know why you're not getting power to the coil but hey might aswell ask....you pluged in the opti harness right?
Mike
Old Sep 28, 2004 | 11:35 AM
jdizzell's Avatar
Not disagreeing w/ you, but I thought the crank sensor on obd2 on start up sends a signal to the pcm on what stroke the number 1 cylinder is so that it can fire the right cylinder for start up.
Old Sep 28, 2004 | 11:38 AM
WS Sick's Avatar
Mike
The fuel pump will not even kick on with the key if the opti harness is unplugged.
Old Sep 28, 2004 | 01:01 PM
Huh....Good to know!!! Thanks for the info lol.
Mike
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
