No Spark Help!!!
Old Mar 12, 2014 | 05:16 PM
Zach James's Avatar
Angry No Spark Help!!!
So i have a third gen that i dropped an lt1 into and it has no spark i have power to the coil i have power to both pin a and d on the icm but no spark from coil
Old Mar 12, 2014 | 05:20 PM
Re: No Spark Help!!!
Do you have the signal on the white wrie from the PCM to the ICM (pin B), that tells the ICM when to fire the coil:
4th Gen LT1 F-body Tech Articles
Have you scanned it for codes? Both a faulty ICM and the cam position sensor in the Opti will set codes if they fail. Some of those codes do not turn on the SES light.
Old Mar 12, 2014 | 05:27 PM
Zach James's Avatar
I am not getting any codes i will test the white wire as soon as i find my ohm meter whats the reading suppose to be
Old Mar 12, 2014 | 05:28 PM
Zach James's Avatar
also i am using a 97 harness with a 94 lt1 and ecu
Old Mar 12, 2014 | 08:44 PM
You have to look at the procedure in the link I posted. It tells you what to test, how to test and what satisfactory readings are.
How did you try to scan it?
Old May 6, 2014 | 09:53 PM
2QUIK6's Avatar
Looks like I'm back to a no start issue again after having a broken opti a year ago, car sat 9 months, after fixing and having another no start issue that turned out to be the fp regulator flooding it....now Sunday car just died at a stop sign and won't start...had to have it towed.
So far the only tests I've done was to see if spark was getting to plugs....nothing. Unplugged coil wire to opti and put the spark plug tester on the end of it and connected it to ground..cranked but got no spark there either...... So now I'm going to do the tests in the link above that Fred posted if the coil ohms out ok..... Time is sparse these days so it could be a week or so before I have time to do this....for space reasons car is up in the air so I can't just go out and do it when I have time.
Guess I need to hook up the DataMaster also and see if there are any codes.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
