No spark at Coil??
Old Dec 27, 2003 | 07:57 PM
acid5868's Avatar
No spark at Coil??
Just finished a top-end rebuild and now when I go to crank it over it turns but I am not getting any spark to the coil.
I replaced the coil, installed a Electric water Pump and new MSD wires. I have tried the stock coil that worked fine before I started working on the car. Also even tried swaping out the coil wire with the stock one and still no luck.
As far as the ground wires go, they are all connected fine. I am curious if anyone happens to know what the black wire on there goes to as I did have the terminal break off and had to replace it?
Help please
Old Dec 27, 2003 | 08:12 PM
crAzy95z28's Avatar
is all your opti spark wires pluged in?
Old Dec 27, 2003 | 09:11 PM
acid5868's Avatar
I double checked my opti wires, they were all fine. Didn't think that my opti would be the cause of it as I need spark to the coil before my opti comes into play, unless I am mistaken.
Old Dec 27, 2003 | 09:28 PM
crAzy95z28's Avatar
yes ytou are mistaken...when i put my new dynasparlk in i forgot to plug in the top switch, which causes no spark no were...
so i plugged it in and it staretd...but good luck on your problem..
randy
Old Dec 27, 2003 | 09:31 PM
InjectedSS's Avatar
Yea dude check your opti... See the ECM gets it's signal from the opti telling it when to fire the ignition coil.. Then the coil fires and sends spark THRU the opti to the plugs...
So if the opti isn't sending that signal to the ECM then the ECM won't be able to tell the coil when to fire. Hence your car not being able to start
Old Dec 27, 2003 | 10:31 PM
acid5868's Avatar
Thanks for the quick responses. The car is now up and running. It is greatly appreciated. Turns out that it was the wire going to the opti. I knew I had it plugged in but totally forgot to check the other end by the Intake manifold.
Once again thanks for the help.
markzzzz
Aug 17, 2015 11:08 AM
greenzee28
Mar 26, 2015 09:13 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
tbyrne
Aug 16, 2002 01:12 PM
