no spark
Old Feb 18, 2008 | 06:52 PM
Domss2000's Avatar
no spark
i bought a new coil, ignition module and opti and starter.But the car i checked the coil spark and nothing so i got another one an nothing again. its weird cause it turned on the first it i tried it. then turned it off and no theres no fire. Does anyone know what it might be? any help is good. thanks.
Old Feb 18, 2008 | 09:16 PM
Domss2000's Avatar
i got it on right now for a while. then gave it gas and it turned off and then no spark again.it will just crank and crank.
Old Feb 18, 2008 | 09:35 PM
ss.slp.ls1's Avatar
I'm assuming you changed the wires with all the new parts, and seated them properly, in the right order?
Old Feb 18, 2008 | 10:35 PM
Domss2000's Avatar
yea i bought everything new plugs wires etc. ill get a spark once then its dead again the spark wont be there anymore its weird im freaking out man lol. but yea i got every thing new. i got no spark at the coil and spark plugs too.
Old Feb 18, 2008 | 10:52 PM
ss.slp.ls1's Avatar
I guess you could check your grounds on the coil. Perform the opti and spark test per shoebox's website, see where it fails.
Old Feb 18, 2008 | 11:19 PM
Domss2000's Avatar
thanks ill try that out on th mornin
Old Feb 19, 2008 | 08:17 AM
2000GTP's Avatar
As always, Shoebox has a good guide in troubleshooting through some of the ignition system: http://shbox.com/1/4th_gen_tech2.html#opti_test Have you checked the connections on the opti harness itself, that would be a good place to start.
Old Feb 20, 2008 | 02:25 PM
Domss2000's Avatar
thanks ill start from there thanks for your info.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
