No spark !
Old May 11, 2004 | 10:01 PM
JONEZ_Z's Avatar
No spark !
I just did Lloyd heads, Joe cam, long tubes, 30# injectors, 52mm tb. And I got a tune from PCMforless. I got the car running and have driven it several days and i drove it for about 2 hours the other night. Now I went to start it today and it doesnt even try to fire. I checked for spark and it has none. I had no signs of opti failure the night before. Like i said, i drove it for 2 hours, romping on it and it didnt even miss. Now this. Anyone have any ideas?
Old May 11, 2004 | 10:11 PM
Z06Z28's Avatar
......so is the starter even winding up? And how did you check for spark? Swap a coil with a buddy real quick and see what happends..that happened to me once.
Old May 11, 2004 | 11:20 PM
Did you check fuses?
Old May 12, 2004 | 05:16 AM
JONEZ_Z's Avatar
Yah, it cranks over fine. I checked the spark by putting a piece of metal in the spark plug boot and the holding it close to the head. I got nothing. Ill try switching out coils with my friends 95 formula. Shoebox,
Would a fuse keep it from sparking?
Old May 12, 2004 | 08:12 AM
If the IGN fuse is blown, there is no power to the coil, therefore no spark. You should check for spark out of the coil if there is no spark at a plug wire.
Old May 12, 2004 | 06:53 PM
JONEZ_Z's Avatar
If there is spark at the coil but not at the plugs, does this mean bad opti?
Old May 12, 2004 | 07:13 PM
Pasky's Avatar
You guess it.
Old May 14, 2004 | 10:40 AM
JONEZ_Z's Avatar
Ok guys, there was no spark from the coil either. I went and got my buddies coil off of his formula and still nothing. This morning before I did any of this i tryed to start it up after letting it set for a few days and it fired up for about 3 seconds then died. I cant figure out what the deal is. Shoebox, when you say ignition fuse, do you mean the one that says PCM IGN or the one that just says IGN? The one that just says IGN doesnt have anything in it. It is a smaller hole that the other style fuse wont fit in. What else could be the problem? Somebody please help me. Thanks
Old May 14, 2004 | 11:03 AM
klbjoc's Avatar
I had the same problem not to long ago after putting to top of my motor back together. One of the connecters fron my ignition box wasn`t snapped back together very well and had wiggled loose.
i would suggest checking all your connections.
Old May 14, 2004 | 11:34 AM
Well, a 1994 may be labeled differently, but look at fuse 11 under the hood. That's the one I mean. If it actually fired for a few seconds it may not be the problem. Look for 12v on the pink wire to the coil when the key is ON.
Old May 15, 2004 | 07:31 PM
JONEZ_Z's Avatar
The pink wire has power. I just checked it. And both fuses, the one under the hood and the one in the dash are both good. Any other ideas? THanks.
Old May 15, 2004 | 07:38 PM
supermo26's Avatar
I blew a fuse for my aftermarket fuel pump and my car did not start. Check for fuel presure as well.
Old May 16, 2004 | 06:53 AM
JONEZ_Z's Avatar
I checked all my fuses and they are good. Is it possible that if the opti is fried that, the computer will tell the coil not to work? That is the only thing i can think of. Cuz everything checks out ok.
Old May 16, 2004 | 09:35 AM
Fuels94TA's Avatar
You said you swap the coil, but did you also swap the ingition module.
Vinny
Old May 16, 2004 | 10:58 AM
You can see if you are getting any signals to fire the coil.
