no more spark - help plz
Old Jan 6, 2006 | 02:14 PM
Sporty-X's Avatar
Hi,
i was driving (quite hardly but that is the aim of my Z28 purchase), when the engine suddenly went off.
I looked briefly at it at home. I have no spark at spark plugs while no engine code. I also looked with my AutoXray scan : nothing wrong.
My question is just : what are the things to check at first to help me save time. I beleive the very first are to check coil and optispark module, as i beleive these can cause trouble without engine code.
Waiting for your answer.
Thks.
Pierre
Old Jan 6, 2006 | 02:26 PM
thehunter's Avatar
Re: no more spark - help plz
Yea, check your coil first. When I had my Z28 I replaced the coil several times due to failure.
Mike
Old Jan 6, 2006 | 03:06 PM
OBE1 95Z28's Avatar
Ignition fuses, Ignition Control Module and coil wire could also be at fault.
Old Jan 6, 2006 | 03:07 PM
OBE1 95Z28's Avatar
Here's a helpful aid from Shoebox's site:
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Jan 6, 2006 | 04:48 PM
smoknta's Avatar
One more for ICM.
Old Jan 7, 2006 | 04:08 PM
Sporty-X's Avatar
I just try the shoebox test for ICM. Reading between A to ground and D to ground should be 10V dc. Mine are just 0.02 V dc ....
the problem might come from ICM so or related to something else ????
Old Jan 8, 2006 | 01:36 PM
Sporty-X's Avatar
I beleive coil is dead.
infinite resistance between 2 primary.
Going to purchase a new one.
Thx for help
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
SEOJustin
Sep 24, 2015 04:39 PM
colts0455
Sep 11, 2015 06:16 PM
