no fuel pressure...why?
i can't seem to figure it out, awhile back i blew some head gaskets, and decided to change my fuel pump, i am now trying to get the car started back up, and i am not getting ANY fuel pressure...
ANY suggestions or ideas, as to why
*please help ASAP*
*please help ASAP*
Re: no fuel pressure...why?
Turn the ignition key on and listen for the pump, u shoul dbe able to hear it if it turns on. If it does turn on then pull it out and make sure all the rubber hoses are still in tact on the pump. If the pump does not turn on, check the connector on the very top of the fuel pump and make sure it is plugged in all the way. Peace, Dustin.
Originally Posted by JP2005
;is their anything i should check before i talk out the fuel pump?
sounds like i have a long day ahead of me
shoebox why does my fuel pump regulator have no place to jump it, it just looks like a rectangular block
The f/p regulator is not electrical.If you want to test the pump, you can jump 12v to the fuel pump prime connector under the hood. I assume you must be referring to the 1993 in your sig?
Yes, that's what I am talking about...my fuel pump prime connector is a block witho no place to jump it at... It doesn't look like the one picture, why?
yes it is right by where the valve covers would be exactly as shown in your picture, except as opposed to showing a metal connector, mine is just a black rectangular cube...why is this, and wtf, i want my car to run
