No coolant flow LT1
Old 07-17-2018, 02:43 AM
  #16
Oysteinbno's Avatar
Re: No coolant flow LT1
Originally Posted by lt1-xjs
https://www.camaroz28.com/forums/lt1...outing-881977/ Look at post 6 for the diagram and post 10 for the routing. If your filler neck is the highest point you should not have to bleed the system, just use a standard overflow tank.
This is how I have routed the connections. But I still have no flow. I'm starting to think that I may have a broken head gasket that generates some pressure in the cooling system.
Oysteinbno is offline
Old 07-20-2018, 03:56 PM
  #17
lt1-xjs's Avatar
Get the AutoZone loan a tool block tester. You'll have to spend $10 for the test fluid.
lt1-xjs is offline
97silverslpss
01-15-2012 06:47 PM
FASTFATBOY
Advanced Tech
22
02-21-2008 12:40 PM
CamaroSS8887
03-14-2007 03:28 PM
FLyinlow89
08-19-2004 01:29 AM
surfinmud
03-26-2003 04:47 PM
Quick Reply: No coolant flow LT1
