No Bottom End
Old Oct 26, 2003 | 11:38 PM
Taylor's Avatar
No Bottom End
My car has no bottom end, It is a 93 z28 A4 with 118,000 miles, new plugs and wires, no cat, air, or egr. The rest is stock. I can mash the gas at a stop and it just slowly takes off, it used to spin the tires. I have also been getting really bad gas milage, around 9 in town and 13 on the highway. The car runs great from about 2 grand and on, it doesn't miss all the way to 5800. I did the seafoam and some injector cleaner, and that helped a lot but it didnt fix it the problem. It seems to run the same hot or cold. I tried a new coil and ICM with no results. When I get on it going down the highway and let off it will back fire and shoot a flame out the tail pipe. And sometimes it wont want to start, mostly when it is cold. Not throwing any codes. Anyone know what is wrong, but for I start spending money??
Taylor
Old Oct 27, 2003 | 12:39 AM
Z95m6's Avatar
i'll say O2's
Old Oct 27, 2003 | 12:49 AM
madwolf's Avatar
It's probably your opti. O2's could also be bad, but they are not your main problem.
Old Oct 27, 2003 | 12:56 AM
turbo_Z's Avatar
ill take a shot in the dark and say its knock sensor related. if for the sensor was signaling the PCM to pull lots of timing for some reason then youd feel a loss in power and drop in gas mileage.
Old Oct 27, 2003 | 01:50 AM
lt195ta's Avatar
definately change the o2s
Old Oct 27, 2003 | 02:42 AM
DrewHMS97SS's Avatar
agree with the o2 sensor idea, you have a service engine light?
Old Oct 27, 2003 | 09:52 AM
madwolf's Avatar
How exactly will o2s cause a backfire and stumbling at WOT? Explain that to me please.
O2s are ignored at WOT. It's obviously an ignition problem.
Old Oct 27, 2003 | 01:16 PM
Brad122470's Avatar
I think he was saying that the backfire was after taking his foot off the gas. I do agree that it sounds like the Opti (root of all evil). That is the way mine started to go. It got progressively worse until I think I could out run the car at take off on foot! The O2's would add to the problem. Also if it has been running pig rich and you're smelling raw gas would hurt to change (at least Check) plugs and wires also if you do have to change the opti.
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
sscott
Jan 17, 2015 04:30 PM
Killer94z
Jan 13, 2015 12:06 PM
RichJ
Sep 26, 2002 09:43 AM
