383 Build worth it?
Old May 23, 2004 | 06:20 PM
StumpDeisel's Avatar
383 Build worth it?
Heyas all, I'm looking at doing a rebuild for my LT1, with a CC305 cam w/1.6 roller rockers, mildly ported stock heads, and shorty headers. There are 383 kits w/ silvolite pistons for $560 on e-bay. It seems like a good deal, is it worth it w/ the setup I'm planning? How much more HP over a non-stroked bottom-end rebuild? How much more machine work will I need to get it installed?
My other question is will ported heads, w/ or w/out a stroker bottom end, cause a fail of the sniffer test? I live in NY...
Thanks in advance for the input...
Old May 23, 2004 | 07:17 PM
AdioSS's Avatar
West South Central Moderator
with the heads, cam, intake, compression, etc all the same, a 383 won't make more power (at least, nothing worth noting) than a 350.
The MAIN advantage to more cubes is the average power aka the power under the curve.
Other advantages are that it will allow a larger cam and heads for the same RPM range which WILL make more power.
Old May 23, 2004 | 07:36 PM
kmook's Avatar
Advanced Tech Moderator
General engine buildup should be discussed in a Generation Spacific Forum. Transfering to LT1 Tech, thanks.
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Noct
Jul 14, 2015 01:18 AM
transam_388
Mar 15, 2015 11:53 AM
Moshbmx1
Jan 20, 2015 03:27 PM
