NJ members> question on Smog check?
Old Aug 6, 2014 | 10:13 PM
DocJhn's Avatar
I have a few days left to get the Z smogged. It seems to burn a little oil while sitting at Idle for long periods of time. Plan was to run the freeway for 30 mins before inspection to burn this off. It prob is a valve guide or two that is causing the dreaded blue tint.
Will this be an issue at inspection time if I cannot curtail ? Thanks in advance!
Old Aug 7, 2014 | 05:22 AM
Re: NJ members> question on Smog check?
They only check emissions. Visible oil smoke could be a cause for rejection.
Old Aug 10, 2014 | 12:36 AM
Fatdog2's Avatar
Change your oil and filter before going for smog.My02.Also,make sure the engine is real hot just before you smog it(let it idle till the fans come on).Hope this helps.
Old Aug 10, 2014 | 07:00 AM
DocJhn's Avatar
Thanks guys! Will do!
alphaauto
Jan 23, 2015 07:42 AM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
