Nitto 555R Drag Radials Vs Road race tires ???
Old Jan 27, 2003 | 03:02 AM
WS6Formula's Avatar
What's the difference between the Nitto 555R Drag Radials & the 555R II Extreme??
Discount tire's description only says that the 555RII is a road racing version of the drag radial, with stiffer side walls.
Will the Drag radial hook up noticably better than the road race tire?
I'm guessing they'll wear about the same since they're both rated as 100 tread ware.
Only difference I can see is that the drag radial is rated to 149 mph, and the Road race ones are rated as W or Y rated.
Thanks a lot!!
Stephen Moretti
Old Jan 27, 2003 | 10:42 AM
Ace_437's Avatar
Yes, you should get much better launches with the drag radials. They have more flex in the sidwalls that help alot with initial traction when you mash the gas. You'd probably spin alot more with the road race version.
Old Jan 27, 2003 | 10:50 AM
bad95z28's Avatar
exactly what it says they have two different purposes. the road race ones are great for that and the drag radials are better for the track.
Old Jan 27, 2003 | 11:10 AM
All_Z_Way's Avatar
Actually a guy I road race with says he can tell know differences between two and the tread design is the same.
I know the sidewalls are supposed to be stiffer, but he said they don't feel any stiffer.
Old Jan 27, 2003 | 11:12 AM
chesee48's Avatar
that would be correct
Old Jan 27, 2003 | 11:43 AM
WS6Formula's Avatar
thanks a lot guys, I apreciate the quick responces, I'm going to go order the drag radials today!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
