nitrous cams?
sure they still run good on motor, they just run better on N2O then an NA cam would
i believe one of the major differences is less overlap so the intake charge doesnt get blown right out the exhaust(?)
The nitrous cams are intended to work best when you are on the button all the time,I.E. at the track. When I was looking at doing the same thing you are. the guys at comp. cams told me to cam the car as if it had no nitrous because that is where I do most of my driving. I even think they said I would lose H.P. when not on the bottle vs. a cam made for non nitrous ap.
