Anyone with pacesetters have to shave steering shaft bolt....
Old Jun 21, 2004 | 10:46 PM
Yby4n95Z's Avatar
The top bolt on the steering shaft rubs the headers bad when I turn to steer with my pacesetter LT's. The top of the bolt I grinded down and it clears now. However the bottom thread part that goes through the shaft is also hitting so I have to cut the bolt a bit shorter. I haven't heard of anyone with this problem so what gives?
Adam
Old Jun 21, 2004 | 10:58 PM
Mystic97Z's Avatar
aftermarket parts are wonderfull aren't they? lol
i hate when you pay good $ for $hit and it doesn't work,
Old Jun 21, 2004 | 11:25 PM
94 CAMRO Z28's Avatar
Try sliding the shaft down some up on top and see if the bolt clears. My bolt doesn't have any issues but the shaft itself does have a clearance issue with one of the primarys under heave acceleration. I think it may be from worn out engine mounts allowing the engine to torque over to far.
Aaron
Old Jun 22, 2004 | 09:12 AM
Hyperspeed97z28's Avatar
I've only got slp (93 style) mid length's but I'm gonna do long tubes soon...
I'm running SOLID mounts.... No Flex here But I would assume thats the problem...
Old Jun 22, 2004 | 09:20 AM
Geoff Chadwick's Avatar
I hate to say it, but I'd never buy pacesetter parts ever again.
I bought a set of pacesetter shorties for the Z long ago - and never again. Firstly the welds looked like ***, the bolt holes in the flange didnt line up perfectly, there was no way to get two of the bolts on the flanges on (the head of any bolt I could get would rest on the weld and not the flange) and the air rise pipe for the EGR wasnt spaced properly at all (hole was I think .25" off!!)
Then one of the primaries wouldnt allow a spark plug to go in. Not even a plug designed for headers. It was stupid.
I called tech support and complained and tried to find out why I was having these problems. Kept talking with them over and over again. Nothing. They kept telling me I didnt know what I was doing and kept saying that my problems werent happening. I even took pictures to send them with calipers showing distances and how bad they were... After nearly 2 weeks of complaints I finally got someone that would refund my money. Turns out they had several sets from a shop in Mexico that failed QC but still went out the door several months earlier and I probably got one of those sets. I got my money back - but never was treated so badly in my life. If I got a bad set, it happens. But when you have a customer saying "this hole is the wrong dimension, I measured it with my calipers and it's this ___"... you dont tell them "no it isnt, you dont know what you're doing." Then to admit fault later and shrug it off "Oh, you just got a bad set." Really? I thought they were fine!
Compared to every other aftermarket part on my car - I've never had anything that bad. Ever.
Old Jun 22, 2004 | 10:49 AM
Loadre's Avatar
Things have changed since then. Their LTs are lightyears ahead of the shorties.
Old Jun 22, 2004 | 11:28 AM
Then would be a year ago...
If things are better then cool - but I'm still staying away from anything they make. This isnt the first pacesetter fitment/quality problem I've had with them. And someone had told me "they were better now" when I got the shorties. Things werent.
Old Jun 22, 2004 | 08:39 PM
Yby4n95Z's Avatar
All is well. Had to cut some of the bottom threaded part of the bolt down and shave the steering linkage. Everything works like a champ.
Adam
GREEN3112
Feb 10, 2019 09:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
