NGK's came pre-gapped at 0.055, is this too much?
Old May 9, 2005 | 02:26 PM
maksik7's Avatar
I'm about to change my plugs and I got some NGK 55's. When I checked the gap its at 0.055, this is too big for my pretty stock LT1. How can I make the gap smaller, or will I ruin the plugs?
Old May 9, 2005 | 02:56 PM
BUBBA's Avatar
Re: NGK's came pre-gapped at 0.055, is this too much?
I believe the recommended gap is .050. It takes very little to tighten the gap on the plugs. Just a little tap will do: then regap if necessary. You can pick up a cheapie gapper that will also narrow the gap for you. Don't forget your anti-sieze.
Old May 9, 2005 | 06:02 PM
Hyperspeed97z28's Avatar
will the 0.055 gap hurt any performance over the 0.050 gap?
Old May 9, 2005 | 06:04 PM
Sweetred95ta's Avatar
No. But it isn't hard to change the gap. Plus, if you gap all of them, you can make sure they all have the same gap. Just tap it a few times with the gapper, then regap them. You won't hurt anything.
Benji
Old May 9, 2005 | 06:07 PM
96m6lt1's Avatar
just remember the plugs we use are not only for our cars so you really need to re-gap them for your application.
Old May 9, 2005 | 07:08 PM
maksik7's Avatar
Thanks for the help guys, I closed up the gap and regapped them to spec as you said.
Old May 9, 2005 | 07:34 PM
sbs's Avatar
sbs
Where are you guys buying plugs?
It's been many years since I've bought plugs that weren't pre-gapped for the specific application.
Old May 9, 2005 | 07:44 PM
Silver's Avatar
Well a lot of them say pre-gapped... and they are... just not to our specifications In other words, I think they shoot for a gap that will work in many applications, hence your 5/1000ths variance. Don't ever instlal plugs these days without checking the gap. Most the time, you'll have to gap them. Might as well get comfortable with it.
You didn't close the gap all the way did you? Just close it a bit or open it a bit until you've got it set right.
HarleyZ28
Oct 5, 2015 06:23 AM
Slayer
Aug 17, 2015 03:55 PM
BMX Dad
Aug 15, 2015 01:15 PM
BLK1997Z28
May 7, 2015 03:01 PM
