NGK R5671-A7 spark plug issue....
Old Oct 11, 2010 | 11:46 PM
nhill_05's Avatar
Question NGK R5671-A7 spark plug issue....
I have recently put a 125 shot on my car and switched the plugs out with ngk r5671-a7 (stock #4091). The thing has not been running right since. I gapped all of the plugs at .032" and triple checked the plug wires.... Now it is running terrible....
So my question is, Has anyone had a similar experience with these plugs or nitrous plugs in general???
If so, what did you do to fix it???
I am planning on throwing a set of NGK TR6s in it tomorrow to see if that will make a difference.
It starts and idles fine, but there is a lot of pinging and it seems like it has a dead miss.....
Any help is greatly appreciated.
Thanks!
Old Oct 12, 2010 | 04:52 AM
RamAir95TA's Avatar
I wouldn't think that those plugs would cause that much of an issue. Sounds to me like you may have some arcing between wires and/or one of the boots not connected firmly or you have a wire crossed.
Old Oct 12, 2010 | 05:17 AM
bw_hunter's Avatar
Isn't that plug a touch hot for your mods? I think it's half a heat range hotter than a TR6.....
Old Oct 12, 2010 | 07:08 AM
nhill_05's Avatar
I've been running tr55s since I built the engine. Ran fine.
Old Oct 12, 2010 | 11:25 AM
Purple Poncho's Avatar
Those are the wrong plugs for your heads. Those are for an aftermarket head. The reach is longer at 0.75 inch and is a gasketed plug.
If you are stock heads you need a tapered 0.708 reach plug like the TR6.
Old Oct 12, 2010 | 11:29 AM
Colder in fact with a heat range of 7, so 2 steps colder then a TR55.
Old Oct 12, 2010 | 01:16 PM
nhill_05's Avatar
Quote: Those are the wrong plugs for your heads. Those are for an aftermarket head. The reach is longer at 0.75 inch and is a gasketed plug.
Thanks! I will try the TR6 plugs tonight to see if that makes a difference...
Old Oct 13, 2010 | 07:39 AM
nhill_05's Avatar
So I tried the tr6 spark plugs to no avail. Same issue. I followed the stickied method for diagnosing a bad opti. All signs point to opti. I will change it today and post my results.
blkWidow
May 3, 2015 08:42 AM
racecarz28
Mar 30, 2015 09:55 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
