NGK R5671-A7 spark plug issue....
I have recently put a 125 shot on my car and switched the plugs out with ngk r5671-a7 (stock #4091). The thing has not been running right since. I gapped all of the plugs at .032" and triple checked the plug wires.... Now it is running terrible....
So my question is, Has anyone had a similar experience with these plugs or nitrous plugs in general???
If so, what did you do to fix it???
I am planning on throwing a set of NGK TR6s in it tomorrow to see if that will make a difference.
It starts and idles fine, but there is a lot of pinging and it seems like it has a dead miss.....
Any help is greatly appreciated.
Thanks!
Thanks!
I wouldn't think that those plugs would cause that much of an issue. Sounds to me like you may have some arcing between wires and/or one of the boots not connected firmly or you have a wire crossed.
Quote: Those are the wrong plugs for your heads. Those are for an aftermarket head. The reach is longer at 0.75 inch and is a gasketed plug.
If you are stock heads you need a tapered 0.708 reach plug like the TR6.
Thanks! I will try the TR6 plugs tonight to see if that makes a difference...
racecarz28
Mar 30, 2015 09:55 PM
