NGK Double Platinum Plugs
Old Jul 11, 2007 | 04:52 PM
Bobsep84's Avatar
Has anybody ever used the NGK Double Platinum plugs? (part# PZTR5A-15) I know most use the TR55 copper plugs but im looking for a plug thats going to last a long time because of how hard it is to change plugs on an LT1
Old Jul 11, 2007 | 05:02 PM
BUBBA's Avatar
I doubt that most people use TR55 coppers. I don't know which plugs those "double plats" are but some use the TR55VX plats and the iradium plats. Perhaps the doubles are the latest version of the plats.
Yes, since changing the plugs is not an easy job, going with longer lasting plugs might be for you. The coppers should last a couple of years if you aren't too hard on them and they are supposedly better conductors than the longer lasting plats and others.
One shouldn't consider the cost as a factor when doing plugs. Paying 6+ bucks per plug becomes a non-issue when you put off having to change cheaper plugs more frequently. And I doubt that the coppers will give you any gains. JMHO
Old Jul 11, 2007 | 05:16 PM
Bobsep84's Avatar
Heres a link on the NGK website that i found these at if you wanna take a look at the ones im talkin about. http://www.ngk.com/results_app.asp?AAIA=1035908
Old Jul 11, 2007 | 05:33 PM
Bobsep84's Avatar
Hmm...i was looking at those TR55-IX ones too...i wonder what the diffrence is between those and the double plats....besides the double plats cost x2 as much
95_Z28/SS
May 20, 2015 01:23 PM
Jazsun
Dec 29, 2014 12:14 PM
CobraEatr
Jul 24, 2004 11:37 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
