new valves?
Old Nov 13, 2007 | 12:47 PM
  #16
BUBBA's Avatar
I don't believe that you "have" to have bronze valve guides when using SS valves, however I do agree that they would be advised if you are changing the guides.JMHO
Old Dec 18, 2007 | 11:54 PM
  #17
blackgold84's Avatar
got the valves
went ahead and got the manleys. (11500-8/11501-8)
they look so sexy, cant wait to have my heads finished. im done porting them and im now polishing the out before i take them to the machine shop, is there anything else i should do before the are assembled?
what kind of valve seals do you guys like?
Old Dec 18, 2007 | 11:56 PM
  #18
MachinistOne's Avatar
cast iron and stainless do not like to rub together - it causes galling of the valve stem and metal transfer. I have seen it a hundred times....seeing is believing
Old Dec 18, 2007 | 11:58 PM
  #19
Are they going to do guides and a valve job?
I use the metal clad viton seals - they allow just the right amount of oil to lube the stems, and will not turn brittle and hard like the nitrile seals that most use. Do not use the teflon seals for a street motor.
Old Jan 7, 2008 | 12:05 AM
  #20
yes, did bronze liners
got the heads back looked really sexy, no inner spring in there wtf, no back at shop putting the clad seal on instead of the umbrella seal, b\c when i went to put on the inner spring the seal was to big around. also i was one inner spring short. will try and post up some pics when i get them back this time, those manley valves to cool in the chambers
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
