Is new tune needed with ported heads and same cam?
Old Jul 6, 2007 | 09:01 AM
kgkern01's Avatar
Adding heads but using the same cam, do I need a new tune or will the MAF correct for the heads?
Old Jul 6, 2007 | 10:56 AM
LiENUS's Avatar
If you're talking dyno tune theyl'l probably be able to adjust your spark curve a little as well as some minor tweaks to fueling to pick up a few horsepower, however if you're talking mail order, you are probably better off just letting the o2s correct for the new heads. But I don't know for sure, email the pcmforless guys and ask if they think it'd be worthwhile
Old Jul 6, 2007 | 11:48 AM
speed_demon24's Avatar
02's don't do anything at WOT. And I went from 391 to 405rwhp on the dyno over my old tune vs getting tuned for the new heads.
Old Jul 6, 2007 | 11:52 AM
LiENUS's Avatar
I believe o2s do affect WOT, they affect the long term fuel trims which afaik are used for WOT. The o2s just arent used in WOT, but the previous input from them is used.
Old Jul 6, 2007 | 12:18 PM
Most tuners tune that feature out so 02's have no affect at WOT at all.
Old Jul 6, 2007 | 12:59 PM
LiENUS's Avatar
I'm not seeing any way to tune out the bank lean modifiers from WOT in tunercat...I think you are mistaken on that. If the O2s werent used for WOT then you would need a retune every time the temperature changed, or every time it rained, Heck you'd need to retune if you drove up a hill.
Old Jul 6, 2007 | 03:24 PM
I know for a fact PCMforless does that and my tuner does that I'm not mistaken.... My tuner uses LT1 edit and I'm not sure what pcmforless uses, theres more software out there than tunercat....
Old Jul 6, 2007 | 08:58 PM
LiENUS's Avatar
I'm not seeing anything in lt1edit or tunerpro rt to do what you are talking about and i couldn't find anything on pcmforless's site about it. And assuming pcmforless does (which i see no reason they would) he wasnt tuned by pcmforless, he was tuned by madtuner.
Old Jul 6, 2007 | 09:06 PM
blue's Avatar
A new tune would be nice but you don't need one. I put ported heads, 220/226 cam, and rockers on my '94 with the stock tune and it ran fine. Gas mileage was the same too.
Old Jul 6, 2007 | 11:17 PM
sbs's Avatar
sbs
It's called locking the BLMs, and tons of people, pros and amateurs alike, do it.
Old Mar 7, 2008 | 06:43 PM
kgkern01's Avatar
With my mods in sig, what should my rwhp/tq be now? I was thinking in the 330-340 rwhp and 350 rwtq range. If so, would it be best to upgrade injectors to 30#?
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
jmzlt1
Mar 13, 2003 07:26 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
