Is new tune needed with ported heads and same cam?
If you're talking dyno tune theyl'l probably be able to adjust your spark curve a little as well as some minor tweaks to fueling to pick up a few horsepower, however if you're talking mail order, you are probably better off just letting the o2s correct for the new heads. But I don't know for sure, email the pcmforless guys and ask if they think it'd be worthwhile
I believe o2s do affect WOT, they affect the long term fuel trims which afaik are used for WOT. The o2s just arent used in WOT, but the previous input from them is used.
I'm not seeing any way to tune out the bank lean modifiers from WOT in tunercat...I think you are mistaken on that. If the O2s werent used for WOT then you would need a retune every time the temperature changed, or every time it rained, Heck you'd need to retune if you drove up a hill.
I'm not seeing anything in lt1edit or tunerpro rt to do what you are talking about and i couldn't find anything on pcmforless's site about it. And assuming pcmforless does (which i see no reason they would) he wasnt tuned by pcmforless, he was tuned by madtuner.
It's called locking the BLMs, and tons of people, pros and amateurs alike, do it.
oldschool
Feb 9, 2016 09:21 PM
Wilson
Jul 21, 2002 05:08 PM
