New TQ converter
Old Jul 22, 2004 | 09:47 PM
  #16
Fux0redImages's Avatar
Re: New TQ converter
I'm no tranny expert, but I think if you didn't hear the 3 clicks and you tightened everything down to go for a drive, you could have destroyed the front pump. I believe that's what it's called. Kinda sounds like you did that to me. Good luck.
Old Jul 22, 2004 | 09:48 PM
  #17
Wildwill2855's Avatar
we lost alot of fluid and we put about 4 or 5 qts in, it wasnt showing on the dip tubehow much was actually there?
Old Jul 22, 2004 | 09:52 PM
  #18
almost felt like a damn busted transmissoin mount just rumblin all that, man i feel like ****, this is what makes me want to leave my car stock lol, its a custom used 3k stall, and it will stall till about 2200 or so but wouldnt spin the tires? i dont know im just frustrated and mad.
Old Jul 22, 2004 | 10:03 PM
  #19
what does a front pump cost to replace? i seen this go all the way to the back of the tranny for sure, and when i bolted it to the fly wheel it cam forward some! i dont knwo about any clicks but it was clearly on all the way i believe. any other ideas here man
Old Jul 23, 2004 | 07:53 PM
  #20
Ok took it to a tranny shop today, they put on a new dipstick gasket itwasnt on all the way, and the tranny lines werent tight, it runs alright i guess, i was expecting a bigger s,o,t,p from a 3k stall that what im getting, my question is, is it normal for there to be so much more vibration than before because it really vibrates bad. from a stop i can spin farther but it doesnt seem any better than i can hold the breaks till 2k or so before they spin, other than that theres not much differnt in any other rpm range?
Old Jul 23, 2004 | 09:42 PM
  #21
I repeat.
Old Jul 23, 2004 | 11:44 PM
  #22
Loadre's Avatar
If you lost a lot of fluid and filled it back up and didn't see it on the dipstick then there's probably not enough fluid. If you overfill it then it just purges the extra out the vent tube on the top of the tranny.
The vibration sounds like a trans mount gone bad. A converter won't vibrate unless it's not all the way seated, etc.
Old Jul 24, 2004 | 10:14 AM
  #23
Ok my buddy drove it for me, that vibrating is the passenger side exhaust pipe, we could only get 1 of 3 bolts back in, i got to get a new header flange put on monday on the exhaust to connect the header, the pipe is bouncing, and feeling like its open headers. so everything is cool and i finally figured how to use the tq converter its pretty ****in cool, its always the same rpms as stock untill i mash it lol !
NewsBot
Sep 14, 2015 02:02 AM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Aug 5, 2015 08:35 AM
