New top end at 136k?
Old Mar 23, 2005 | 05:49 PM
J96Z's Avatar
Well I think I blew a head gasket so I'm pulling the heads. My car has 136k on the odometer. Is that too many miles for a head rebuild and hotcam kit? I just got the driver side head off and I can still see the crosshatch in all the cylinders and there is no lip at the top of the cylinders. I have ran Mobil 1 in the car since I bought it with 30k on the odometer. What do you all think? It never has burned oil either.
Old Mar 23, 2005 | 06:04 PM
FuryZ28's Avatar
Re: New top end at 136k?
My engine had no problems whatsoever, but I did a heads/cam swap @ about 120k miles. Nearly 20k & 2 years since, and it's still running great...
Old Mar 23, 2005 | 07:14 PM
J96Z's Avatar
I am installing 94-95 RK Sport headers and y pipe, SLP loudmouth, 3" carsound cat, Hotcam kit, Edelbrock 52mm TB, new opti, water pump, and am planning on having the pcm reprogrammmed by pcmforless as well as having the heads freshened up at a local machine shop. Any guesstimates on power output? I wonder how long my original 136k auto trans is going to last?....
Old Mar 23, 2005 | 07:22 PM
ManicHaze's Avatar
My tranny just went out at 128K, I now have about 131K on my car. Then again i had a shiftkit in it and I broke a band. I love my new tranny though, snaps necks man.
Old Mar 23, 2005 | 07:28 PM
fastbird96's Avatar
I put a new top end in mine at 130k. Car now has 154k and I haven't had any problems. Sounds like your engine has been taken care of and is in good shape so I say go for it.
Old Mar 24, 2005 | 07:04 AM
1-bad-z28's Avatar
From the research I have done, it is a 50/50 chance that you will spin a rod bearing. Mine was perfectly fine, ran really good, then I ported and polished the heads and dropped in a hotcam kit. Then BAM.....500 miles later I had a spun rod bearing. If I had it to do all over again, I would have took a little extra time and threw in new bearings and rings.
Old Mar 24, 2005 | 08:12 AM
Antz97ZNJ's Avatar
Save a bit more and you can have a complete rebuild and heads and cam for not much more...IMO I wouldnt do anything until a rebuild w/ those miles...but thats just me
Victor Lamb
Aug 26, 2017 02:52 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
