New timing chain on old sprockets
Old Jun 15, 2004 | 07:38 PM
southern78's Avatar
Is there any harm in putting a new timing chain on old sprockets? The sprockets are in perfect shape.
Old Jun 15, 2004 | 08:28 PM
RE AND CHERYL's Avatar
I wouldn't do it. Seen a chain break once because because it was run on the old crank gear. Turns out the GM piece and the replacement had slightly different teeth pitch dimentions and destroyed the chain. It's not much more work to change the gears.
Old Jun 15, 2004 | 08:46 PM
Don 97 SS's Avatar
It is not recommended! I'm sure some have done it but I would not recommend it.
Old Jun 15, 2004 | 09:28 PM
bunker's Avatar
sprockets mesh in with the old chain, its safer to leave the old chain then put a new one on that will not contact the teeth properly & will most likely break.
Old Jun 15, 2004 | 09:39 PM
Never have I put on a new chain without new sprockets. They all establish a wear pattern with each other.
Old Jun 15, 2004 | 10:03 PM
southern78's Avatar
Cool deal, I'll grab some new sprockets.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
