New timing chain with cam upgrade?
Old Feb 4, 2004 | 09:53 AM
CMGETSM's Avatar
Installing an LT4 hotcam kit with the 1.6 rrs and was needing to know if I have to get a new hd timing chain set. If so which one? If LT4 HD set then do I have to switch to a vented opti? I just got a new opti and this is on a 94 non-vented.
Will also be adding a 100 shot dry nitrous set up.
thanks.
p.s. I meant to say timing chain kit not just the chain.
Old Feb 4, 2004 | 09:57 AM
scoobysnax83's Avatar
Re: New timing chain with cam upgrade?
thanks.
If you are adding nitrous, then you for sure 100% need to replace it. Either way you should. LT4 HD will be perfect. But you can just get a LT4 replacement chain. Here ya go.... click me!
Old Feb 4, 2004 | 10:03 AM
S.J.S.'s Avatar
No offense but you don't wanna just change the chain if your switching to the HD chain. Get the whole kit. You can get them for about 190 bucks. Do it right the first time.
Old Feb 4, 2004 | 10:05 AM
CMGETSM's Avatar
So then do I have to get a new non vented opti. I was reading Scoggin Dickey's description and they say... well I'll attach a link to the page below.
http://www.sdpc2000.com/cart.asp?act...d=887&pid=1839
Old Feb 4, 2004 | 10:06 AM
I thought I specified that, but not very clearly I guess. You should definitely replace the while unit, but budget doesn't always allow that.
Old Feb 4, 2004 | 10:24 AM
Compstall's Avatar
So if I buy the LT4 HD timing chain KIT, do I have to change anything? Will the stock timing cover/opti/etc. work?
Old Feb 4, 2004 | 10:34 AM
Mtrhds94Z's Avatar
You have to change cam, opti, timing cover, and opti harness to 95 style..
Also add vacuum lines for opti..
Old Feb 4, 2004 | 10:37 AM
CMGETSM's Avatar
Is there an HD chain kit out there that I can use the non-vented opti with? Please say yes. I just bought and put on a new opti...
Old Feb 4, 2004 | 10:47 AM
Compstall's Avatar
ehh, screw it, I'll just get a stock replacement set then.
Old Feb 4, 2004 | 11:03 AM
ibanez6rg's Avatar
You can't put a double roller on a non-vented setup.
Old Feb 4, 2004 | 11:09 AM
CMGETSM's Avatar
Then do I absolutely need an HD kit. How about just replacing it with a new stock one like someone said above?
Old Feb 4, 2004 | 11:10 AM
Newbie97's Avatar
You dont want to do that. For the cost of a new opti and the ex duty chain. Just get a cloyes double roller and a csi pump and you want have to change the opti. and you will probably save $100 or so and free some hp up with the electic h2o pump.
Old Feb 4, 2004 | 11:14 AM
ibanez6rg's Avatar
You don't absolutely need to convert.
Old Feb 4, 2004 | 11:15 AM
CMGETSM's Avatar
Will this really work? Do you know of anyone who has done this? What other parts are needed, and where to get them?
thanks.
Old Feb 4, 2004 | 11:16 AM
Not a bad suggestion, but you're getting into a little more work with that... But not more than upgrading all the other components for the LT4 ED.
