New times with LE3 383
Re: New times with LE3 383
[/QUOTE]
A 1.95 60 ft while running 11.9 at 122 MPH looks VERY promising. Get the 60 ft in the 1.55-1.60 range and you should be in the 11.3-11.5 range. QUOTE]
I've heard every .1 sec u take off ur 60 ft is .2 off ur 1/4 so wouldnt it be closer to 11.15-11.2?
holy ****.. 457rwhp N/A! That's sick, how big is that cam.. has to be a solid lifter setup? Are those still LT1 heads (my guess is not)? What intake are you running a ported LT4? or single plane?
well i guess i shouldn't say untuned, it does have a mail order tune but it needs quite a bit of work, They are still stock casting heads and the cam is an LE4 which is the same as an LE3 but for the stroker(still hydraulic). The intake is a LT1 intake that was ported by Lloyd with a58mm TB. At first i thought the dyno numbers were off (on the high side) but with my mph and weight they seem to be pretty close. And the CR is just over 12:1
Scott
Scott
im still trying to figure out how the hell you pulled 446 rwhp lol even though i have the 383 le2 setup plus its in a A4 and i only pulled 367 rwhp can you send me a detailed mod list and pm me?
Originally Posted by Josh'95Z28conv
You have less flowing heads, and the power they do make is absorbed more in your A4 than his M6.
Originally Posted by hsyr
Worth 70rwhp? I'm glad were seeing 383s finally make these numbers and mph! Nice work
Anyway, judging by the 122 trap I would expect 11.teens with a good 60'...
--Alan
Originally Posted by Black6spdZ
thanks for the comments guys with what the dyno graphs looked like and the way the car feels i am hoping to squeeze quite a bit more out of it yet.
scott
scott
