New times and almost 10s on the bottle.
Old Oct 28, 2007 | 07:36 PM
Z-RATED94's Avatar
Wink New times and almost 10s on the bottle.
Finally had some decent weather today. 60 degrees and a DA of about 700. Anyways, finally broke into the 11s on motor. Made two motor runs and two nitrous runs. An 11.93 @ 114.28 and 11.94 @ 114.57. About 2 tenths better than my previous best but the same mph. My first nitrous run (125 shot) was 11.08 @ 121.91mph. The second was a 11.14 @ 121.72.
This is spraying from 4k to 6k. With a little more fine tuning and lowering where the nitrous comes in at, I think it will crack a very high 10. Not to shabby for a 222/226 cam and a set of LE heads.
Old Oct 28, 2007 | 07:43 PM
96flame's Avatar
Congrats on cracking the 11's NA
Old Oct 28, 2007 | 09:15 PM
Bersaglieri's Avatar
It's amazing how well a dialed in combo can work. Well done man, hope you see 10's soon.
-Dustin-
Old Oct 28, 2007 | 09:29 PM
Z-RATED94's Avatar
-Dustin-
Thanks, but sooner or later I'm going to have to upgrade some parts, like your doing. Stock bottom end, trans, and rearend, somethings gotta give.
Old Oct 28, 2007 | 09:46 PM
Yea..exactly. My trans pooped the bed first, replaced with 4L80E. The rear pooped once, had it built again, and has been working good. Although I have 9in parts littered around the room After I get the Cummins dialed in *cough* currently 34psi *cough*, forged small block parts will be anticipating spun bearings and broken rods.
What 60's you cutting?
-Dustin-
Old Oct 28, 2007 | 10:08 PM
Z-RATED94's Avatar
-Dustin-
Usually 1.65s, today a 1.63 and a 1.61 NA. With the nitrous coming on at 4k, a 1.58 and a 1.57. Had a good day with the tree today, .114 .140 .132 and a .134 in that order. On the other hand, my first run I was up against a guy that cut a .002.
Old Oct 28, 2007 | 11:15 PM
Mtxz453's Avatar
-Dustin-
i agree
Old Oct 29, 2007 | 12:28 AM
Gun5's Avatar
-Dustin-
ya no joke its not all about power
makes me think twice about my setup below, iv never tracked it but i always thought mid-high 12's
Old Oct 29, 2007 | 10:13 AM
91RSLT1's Avatar
Rick,
Congrats on high 11's NA Lower the N2O to ~3000-3500 that or up the jets to 150. Either way 10 are yours for the taking.
Old Oct 29, 2007 | 11:25 AM
Z-RATED94's Avatar
Our set-ups are pretty close. If it's in good tune you should hit the track. You might be surprised at what it can run.
Old Oct 29, 2007 | 11:30 AM
Z-RATED94's Avatar
Originally Posted by 91RSLT1
Rick,
Thanks James. Time to put the car away for the winter, but that's the plan come spring time.
Old Oct 29, 2007 | 11:36 AM
SS MPSTR's Avatar
Nice.
Old Oct 29, 2007 | 11:42 AM
Z-RATED94's Avatar
SS MPSTR, that means something from one off the guys that knows way more than I do about modding. I try to weed out the good advice from the hear-say advice and put it to good use. This has taken awhile but is starting to pay off nicely.
Old Oct 29, 2007 | 11:45 AM
SS MPSTR's Avatar
You car runs well - I'm really happy to see your dedication pay off too.
Update your signature
Old Oct 29, 2007 | 12:49 PM
3DFORMULA's Avatar
You should be there for sure with that combo. I just ripped a 13.009 with a 100% stock motor(internally) in the 'bird. I do have 3.73 gears in it now.
