New timeing chain is loose.
Old Dec 22, 2004 | 01:32 PM
SSmoked's Avatar
I just bought a new timeing chain from AutoZone and when i put it on with the new gears their is allmost 1/2 inch of movement. How lose is it suppose to be and should i take it off and get another one?
Old Dec 22, 2004 | 01:42 PM
1stz28's Avatar
Re: New timeing chain is loose.
It should not have 1/2 inch of play...something is not right.
Old Dec 22, 2004 | 02:02 PM
SSmoked's Avatar
I know that is excessive, but i dont understand why. I installed it properly, cam gear at 6 o'clock and big one at 12. It went on easy, not like i stretched it when putting it on. Should i just get another one from AutoZone? They had to special order the one they gave me. I haveto start putting this motor together, my car is sitting about 5 feet off the ground im my garage.
Old Dec 22, 2004 | 05:34 PM
XxXTransAmXxX's Avatar
If the block's had any machine work done to it, i.e. line boring, or splayed mains, anything to mess with the crank journals, then it could cause it to be a little more loose, but not too substantial, I just went with an aftermarket one the machine shop got for me....
Old Dec 22, 2004 | 06:23 PM
n2oCamaro's Avatar
I had this happen too. Due to the machining for the splayed caps, the centerline of my crank was raised slightly. I had to get a .010 shorter chain to compensate. Cloyes has special part numbers for .005, .010, and .020 just for this. (If you are running an electric WP that is)
Old Dec 22, 2004 | 10:05 PM
SSmoked's Avatar
Only thing ive done to the motor is springs, cam, timeing chain, and headers.(It is out of the car now) I pulled it from a 95 and it was all stock. I put the new timeing chain on, and its just about if not more loose then the stock one with 58k miles on it. I just don't understand. Im going to call AutoZone tomorrow, hopefully they gave me the wrong one or something. Everyone knows how they do that.
Old Dec 22, 2004 | 11:31 PM
Evil Eric's Avatar
my new one was loose like that to, it wasnt to bad so i just left it and put the car back together. its pulled to 6000k several times and hasnt exploded yet.
Old Dec 22, 2004 | 11:43 PM
SSmoked's Avatar
How loose Eric? Mine isint quite 1/2 inch but its damn close. Not loose enough for me to pull the chain off without the pulleys but with i 6k rpm spin you never know. I just dont want to crank the bitch over when i put it back together and find out i haveto take it all apart again. It's allready been a pain in the *** with the motor out of the car. I couldint imagine with it in.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
