new TB NEED SOME HELP!!
Old Jun 19, 2006 | 01:10 PM
  #31
OrbitalChris's Avatar
Re: new TB NEED SOME HELP!!
so who/where can I get it scanned? or can I buy one
Old Jun 19, 2006 | 01:26 PM
  #32
can you get them somewhere local..ill go buy one now lol I need to fix this thing,,,
Old Jun 19, 2006 | 01:46 PM
  #33
WhyHelloOfficer's Avatar
Most discount auto parts stores will do scanning for you.
That seems to be a problem because the car isn't running however. How close are you to a DAP?
Old Jun 19, 2006 | 02:33 PM
  #34
Your 96 is OBD-II. You can buy cheap scanners for as little as $40 (Harbor Freight). Our local Pep Boys chain store had an Actron OBD-II scanner for $60 this weekend.
Old Jun 19, 2006 | 04:09 PM
  #35
BUBBA's Avatar
Dump the Holley and get an AS&M. JMHO
Old Jun 19, 2006 | 09:21 PM
  #36
AlwaysCode390's Avatar
Wow, this is sorta making me shy away from installing my 52mm t.b. this weekend, hahaha.....good luck man ---
Old Jun 19, 2006 | 10:40 PM
  #37
no man its just cuz I jacked up the TPS, I bought a scanner, and it came back with P0122 code " TPS/Throttle Position Sensor A Circuit Low Input", so injuneer if you can tell me what to do from here Ill be more then happy to fix it now that I know the problem lol (new TPS?) anyway thank you very much for your help everyone
Old Jun 20, 2006 | 10:05 AM
  #38
P0122 = Throttle position sensor circuit low.
The PCM is seeing less than 0.20V with the throttle in closed position. It needs to be above 0.20 to get rid of the code, and to allow the PCM to set a baseline figure for the 0% throttle position. Its usually pretty easy to set it to 0.50-0.67V. You can slot the screw holes to make minor voltage adjustments. But the PCM doesn't really care, as long as the closed throttle voltage is between 0.20-0.90V.
You either have a faulty sensor, a problem with the blue wire, or the sensor is not being installed correctly by indexing it over the flats on the blade shaft.
Old Jun 20, 2006 | 10:22 AM
  #39
95z383lt4's Avatar
now that you have your scanner, where is you iac at? If it is wide open, you probably only need to adjust your stop screw to open your throttle which will also increase your throttle position voltage.
Old Jun 20, 2006 | 01:09 PM
  #40
but theres only really one way to get it onto the flat sections on the blade shaft...I mean it cant really go on another way plug on the bottom facing out? Ill just get a new TPS and see what that can do? and how do I check the Iac with the scanner?
Old Jun 20, 2006 | 03:38 PM
  #41
well I replaced the TPS, and now it runs, but it still makes that whining noise alittle and it runs at like 900rpm idleing but it keeps revving up to like 2k by itself then back down again?????
Old Jun 20, 2006 | 03:56 PM
  #42
and this whining noise is ridiculous, it sounds like its coming from the throttle body, or somewhere close to it...[EDIT]
NOTE FROM MODERATOR: Do not override the language filter.
Old Jun 20, 2006 | 04:43 PM
  #43
do you think that me pull/pushing on the IAC pintle couldve messed it up, making that whining noise?? cuz now it runs..juust ****ty idle with that noise...
Old Jun 20, 2006 | 05:30 PM
  #44
yotaman96's Avatar
Are you absolutely sure the elbow is on the throttlebody good. It's easy to have the bottom fold up in the tb instead of sealing around the outside and you may not be able to see it.. It will make a huge air noise. Feel around the elbow and make sure it's on all the way.
Old Jun 20, 2006 | 05:32 PM
  #45
yotaman96's Avatar
Oops, didn't see you had a trick flow. Guess that wouldn't be the case. Unless the rubber gromets are easy to fold up as well.
