New or stock lifters
Old Feb 27, 2005 | 06:10 AM
Grimpala's Avatar
A friend of mine told me that when he did his cam swap in his 94Z he took the old lifters out, cleaned them really well, and put them back together adn ran them. He was running the cc306 with 1.6 non roller rockers and turned it to 7000 quite a few times.
My question is this, can I 'rebuild' my stockers and run them as is, would I need a rev-kit if I did this?
Or should I buy a new set of the comp stock replacements.
My motor is running the cc306 with 1.6 full roller rockers, and it wont see anything past 6500 or so, maybe a bit more every now and then at the track.
Old Feb 27, 2005 | 07:30 PM
Built on Sin's Avatar
Re: New or stock lifters
New lifters are not required, but are recomended.
Old Feb 27, 2005 | 10:14 PM
Grimpala's Avatar
I've heard that the main thing that causes a stock lifter to fail is that it gets trash in the oil holes and the spring fails, so I'm thinkin that if they are super clean they should be okay for 6500 or so.
Old Feb 27, 2005 | 10:29 PM
turbo_Z's Avatar
With a higher lift cam like the cc306 I think it would be a good idea to upgrade to the Comp "R" lifters.
Old Feb 27, 2005 | 10:59 PM
Grimpala's Avatar
Well after talking to SStrokerAce for a lil while I've about decided that the 306 is too much cam for my 4600# boat. I'm probably going to end up with a custom grind and a few other different things, but either way, I appreciate the help you guys!
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
