New "starting the car" annoyance...
Old Nov 2, 2005 | 12:51 PM
1996TA's Avatar
Maybe I'm being picky but for the past month it takes two key strokes to get the car started. The first stroke just seems to turn the engine over, on the second key stroke it fires up immediately. It happens all of the time now, engine cold or engine warm. Once on, it runs like a champ!
Should I be on the lookout for something?
Old Nov 2, 2005 | 01:08 PM
95GRNZ's Avatar
Re: New "starting the car" annoyance...
How long you need to crank it the first time? If it is more than just a second or two, it could possibly be that your fuel pump is on its way south.
TS
Old Nov 2, 2005 | 01:12 PM
OBE1 95Z28's Avatar
Verify that your fuel pressure isn't dropping off once the fuel pump primes (first 2 seconds after the key is in the run position (not the start position). If your fuel pressure drops off, then the check valve, integrated into the in tank fuel pump, has failed or dirt has it stuck in the open position. This is a common cause of hard starting.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
