new setup cant get into the 12's
Old Apr 18, 2006 | 07:43 AM
  #16
runninfromthelaw's Avatar
Re: new setup cant get into the 12's
I do have the temp datamaster program that i can do a log.but i never did find out how long to do a log for.should i start from start up and run it throught the gear after it warms up or what?
What ever help anybody help me solve this problem.
Old Apr 18, 2006 | 01:13 PM
  #17
robb4964's Avatar
Originally Posted by runninfromthelaw
Guys i need some help!I just got everything i think up to par to run in the 12's.I'll give the long side of the story so you guys can help.I rebuilt a 97 lt1 for my 95'.Added the hotcam,hd timing chain,melling hv oil pimp, canton 7qt oilpan,1.6rr,home ported exhaust stock heads,lt hookers,exhaust cutouts,eletric water pump,moroso cold air,granitteli maf,ovc talor wires,tune by madz28.Thats in the motor.
Stage 2 spec clutch,adj lower control arms,adj panhard,reloction brackets,stock 3.42s in the rear.
I have a scan master and a maf translator but i cant seem to get this setup even to the 13.20s that i ran on the old motor with just the cam and headers.
I ran a best of 13.43@104 60ft 2.0 on nittos last week.then i snaped the drive shaft.So the steel stock ones going back in.
So if you have any ideas or hints on how to help.
It will run 12's right now with your traps. 12.5 is possible.
Old Apr 18, 2006 | 01:20 PM
  #18
how is that with my trap speed be at 104 now I think i would have to get a 1.4 60ft befor with it at 109 yeah but now now.
Not unless you have a few pointers for me to get it to that point
Old Apr 18, 2006 | 09:51 PM
  #19
roguedriver's Avatar
It won't run 12's with a 104 trap. Best I put down N/A in albuquerque was a 13.79 at 104 with a 2.0 60ft. That was when I was running about 285hp and 280ish on the torque side at the wheels with a 4.10 gear. You should really get that thing on a dyno and see what your putting down and what kind of A/F's your running with your set up. You may be leaving some on the table. You may be able to scrap up a couple of tenths with a better 60ft, but with your set up, hooking up is one thing, but having the power to actually get out of the hole after you hook and not bog is another.
Ken R.
Old Apr 18, 2006 | 10:46 PM
  #20
robb4964's Avatar
Ken R.
I missread it. I thought he said he was trapping 109." I looked at his sig"..oops
Old Apr 18, 2006 | 10:57 PM
  #21
robb4964's Avatar
[QUOTE=BUBBA]
Remember that a completely stock lt1 usually won't even break 14 so your numbers look pretty good to me given what you are working with.
QUOTE]
Out of all my LT1's "5 total" Only one did not make it to the 13's stock so most will .
As for your numbers,depending on your DA, your traps are very very low as a set of Long tubes and a few bolt ons should have netted you a 104 trap speed.
With your setup you should be trapping at least 106-107 and a few of my friends have similar setups and are running 12.6's and trapping 108-109 .. My old 6 speed lt1 hit 12's with shorties,tune,clutch,gears,sticky tires.
Id get rid of the translator and maybe speak with the person who tuned your car and see what his take on it is.Is it throwing any codes? False knock or anything could retard the timing and take some power. I saw some other members mentioned the times where about expected but to be honest they arent. Somethings up. With that being said I hope you find the problem. And sorry I couldnt be more help.
Old Apr 18, 2006 | 11:23 PM
  #22
I sent an email to ion for help with the tune.I hope he might beable to do some more for the car.Also Is there much more that i can do to get the best out of this setup.I took off the translator (didnt run it anyway)I also forgot to add the old setup was on the stock 16s now i have stock zr1s off an ss so adding the wheels did that hurt my trap speed?
But if there are any small bolt ons that i can add to help or any track tips please add them I just want a 12sec time slip out of this car I'm going again the 28th so if i can do it by then please post.
Old Apr 18, 2006 | 11:35 PM
  #23
robb4964's Avatar
You shouldnt need anything else. Id wait for him to email you back. There are so many variables that it would be impossible to diagnose this problem over the internet. He may have an answer for you. Just be patient and youll get it figured out. I know thats easier said then done.
See what he says and go form there.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
