Anyone have a set of LT1 castings handy??
Preferably ported, but not absolutely necessary. Need someone to take a look at the intake runners and tell me if ANY of the rocker stud holes come all the way through. Thanks.
Re: Anyone have a set of LT1 castings handy??
Originally Posted by MeanGreen97Z
No rocker arm studs should be seen inside the intake runners. Are yours visible? Not a good thing.
Yeah, it's there. From what I understand, it's always going to go through when you have ported heads. Then again, I'm always open to the possiblity that I'm wrong.
Ian
Ian
Thanks for the confirmation guys. Looks like I may have stumbled upon why my old motor/setup never ran right. I had replaced the studs at one point immediately after the new shortblock and never used sealant. I had NO CLUE that those holes went all the way through, much less that I could lose vacuum and seep oil through them.
Sure would explain my wacky (quickly wavering between 3-8/10 in/hg) vacuum signal since not every intake runner has a rocker stud hole that goes all the way through.
Oh well, too late to go back now.
