New Radiator
Old Apr 18, 2011 | 09:16 PM
96LT1TX's Avatar
New Radiator
How tough is this install? It seems really easy once the coolant is drained; just me?
Old Apr 18, 2011 | 09:20 PM
96LT1TX's Avatar
Re: New Radiator
Also, what is the best radiator for the LT1? I am about to buy just a standard summit one; should I not?
Old Apr 18, 2011 | 09:28 PM
Mike-94 Formula's Avatar
Re: New Radiator
I did it 2 years ago with a lift and nothing about an LT-1 except the trans mount is easy,also I bought a direct replacement.
Old Apr 18, 2011 | 09:32 PM
96LT1TX's Avatar
Re: New Radiator
Ya, I know nothing is easy... had the LT1 for 11 years now rebuilt the motor twice. I have replaced like 6 or 7 optis now and I have a coolant leak. I only get 2 weeks to fix the leak so worst case I will have a replacement radiator just incase. 100 shot at the track here I come!!
Old Apr 18, 2011 | 09:37 PM
my1994z28's Avatar
Re: New Radiator
Dont forget to bleed the air out of the cooling system..
Old Apr 18, 2011 | 09:47 PM
Re: New Radiator
Oh man i'm with ya, had mine 10 years and it's got 140K,2 ECM's, 5 opti's, rebuilt and upgraded trans at 90K and now it just started flaring up and thumping going into 3rd all of the sudden,motor is smoking,been leaking oil like crazy for years but think i got that cured with the timing cover/water pump drive hole drill and throwing the factory oil warmer/cooler in the trash and i'm not even going to mention how many trans mounts i've replaced plus it now has broken motor mounts which cost 150 bucks each at advanced.All that wouldn't be so bad if it was me running the crap out of it all the time but it's been my wifes everyday driver for 100k! So in a nut shell I HATE AN LT-1 and it's gone this year!
Old Apr 18, 2011 | 10:22 PM
Jlo's Avatar
Jlo
Re: New Radiator
I just did mine this weekend..just jack up the car it's much easier to work from the bottom of the car..My car's ac does not work so I removed the condensor along with the rad..it's much easier to put it all back together..
Old Apr 23, 2011 | 12:04 AM
96LT1TX's Avatar
Re: New Radiator
I have AC delete pulley already installed, no condenser in the car. I think it will be an easy job. So stock radiator or aftermarket? Which is better? I have never had temp problems but with the nitrous now I want to make sure.
Old Apr 23, 2011 | 11:06 AM
RamAir95TA's Avatar
Re: New Radiator
Stock is more than enough and will provide the least amount of hassle. I run a stock radiator, stock fans, and an electric water pump in my car and (with reprogrammed fan temps) the temp never gets above 190.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
