New Pump and Still No Oil Pressure
Old Nov 2, 2005 | 06:16 PM
  #16
94Camaro_Z_28's Avatar
Re: New Pump and Still No Oil Pressure
Yes, there is a plug that goes into the block that if it isn't there you wont be able to obtain a good oil pressure, but I doubt thats the problem here...sounds like a freak occurance. At least you caught it before any damage was done.
Old Nov 3, 2005 | 12:39 PM
  #17
LqMth's Avatar
Finally got it back together last night. Oil pressure is about 80psi - cold and 35-45psi - hot, at idle. Runs like a champ. Still not sure the order of events but the pump locked up, drive gear sheard off, and the shaft spun inside the pump gear. I think the pump probably went first. At least I know everythings new now. Thanks for your help. Nathan
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
