160 thermostat
Old Sep 10, 2005 | 11:20 AM
Honda Hunter's Avatar
160 thermostat
What happens if you run a 160 thermostat (hypertech) with A stock tune?
Old Sep 10, 2005 | 12:08 PM
sssalah's Avatar
Re: 160 thermostat
The motor will run cooler at highway speeds when enough air is flowing to the radiator, but it will be the same in stop and go trafic since it depends on the fans for air and these will kick in at the stock settings.
Personaly I wouldn't run an LT1 without one stock tune or otherwise.
Old Sep 10, 2005 | 12:17 PM
Re: 160 thermostat
I ask because it overheated today and blew a head gasket. I'm running with a stock tune so I thought that may have been the reason. Where do you live in Bahrain, I also live in Bahrain. Hoora to be exact.
Old Sep 11, 2005 | 09:58 PM
r6bullets's Avatar
Re: 160 thermostat
I actully removed my 160 t-stat from my car since it seemed to never get out of open loop and ran way to cold. My car runs way better with the 180
Old Sep 11, 2005 | 11:12 PM
Re: 160 thermostat
It takes about 140° to go into closed loop. If all other closed loop parameters were met, there must have been something else wrong.
Old Sep 12, 2005 | 01:55 AM
sssalah's Avatar
Re: 160 thermostat
Surely the overheating have nothing to do withthe 160 stat. There is some other issue that caused it either water or air related.
Currently I'm living in A'Ali.
Old Sep 12, 2005 | 02:27 AM
Re: 160 thermostat
Nevermind. I blew a hose and that's why it overheated. One of my heater hoses blew. Do you race up in salmabad?
Old Sep 12, 2005 | 05:22 PM
r6bullets's Avatar
Re: 160 thermostat
Yea not sure what it was but my car didn't seem to enjoy it, but I am enjoying the CC305 cam I just installed
Old Sep 12, 2005 | 07:32 PM
Jazsun's Avatar
Re: 160 thermostat
Bingo I had the same problem, it takes for every to warm up w/ a 160. LT1's were made to run hot. I wouldnt recommend the 160 as you wont get hardly any gain anyways.
Old Sep 12, 2005 | 08:09 PM
r6bullets's Avatar
Re: 160 thermostat
Yep, hardly any gain and the car burned more fuel. Not worth it in my book
Old Sep 12, 2005 | 09:24 PM
Re: 160 thermostat
Hmm...well, it has been dynoed to show power gains, but if you live in a cold climate, maybe not. I think most people would say a 160° is worth it. I do change to a 180° in the winter.
Old Sep 12, 2005 | 10:42 PM
ss#1230's Avatar
Re: 160 thermostat
yeah, i live in california. it helps. i put my supercharger on and my temps went up to 215-225deg. i threw in a 160 and it runs a nice 175-185. and i dont think that LT1s were meant to run hot, it just happens. a cool engine is a happy engine....
Old Sep 13, 2005 | 07:18 AM
Steve0's Avatar
Re: 160 thermostat
I installed one over the summer. The car runs much cooler and I experienced no loss in gas milage. I may have to swap back to the stock 180 during winter, but we'll see....
Old Sep 13, 2005 | 01:52 PM
ss#1230's Avatar
Re: 160 thermostat
hey shoe....will my car running this cool cause me any problems when it come smog time????
im also running autolite 104s instead of the recommended 106s.
thanks,
jerermy
Old Sep 13, 2005 | 01:57 PM
Re: 160 thermostat
thanks,
jerermy
I can't really tell you. I don't have to deal with any smog testing where I live.
