new problem, need help quickly
Old Nov 16, 2008 | 12:52 PM
x24-7x's Avatar
Ok originally my car would hesitate/backfire a lot of times around 2500 or more. Then it started to where it took about 5 seconds for it to start. I got my codes ran and it said my 02's were leaning out. So it possibly could have been denonating? So i replaced one of my o2 sensors (havent replaced the other yet, will be doing today, along with fuel filter). Its still having the same problem except worse. Last night i got on it a bit and it took till about 3500 to start to hesitate and then when i got off the throttle it died. I tried cranking it about 5 times around 5 seconds each. Finally it started. Now this morning, it is freezing outside, and it wont start. Cranked for almost a minute, several times, letting the fuel pump prime, and it just wont start. Any help is appreciated i need it quickly!
Old Nov 16, 2008 | 02:40 PM
Checked spark? Sounds like an opti issue.
Old Nov 16, 2008 | 02:43 PM
LaredoZ28's Avatar
You can also checkout shoeboxes page if you dont know how to do some things. many ppl have found it very helpful I know i have.
Old Nov 16, 2008 | 10:10 PM
What year is the car? What were the EXACT numerical codes? Have you ever checked the fuel pressure?
Old Nov 17, 2008 | 08:28 AM
x24-7x's Avatar
I actually need to get a fuel pressure guage. So no i havent, but i believe either my coil or opti is bad. I had my ICM checked and it was fine. I actually have another coil so im gonna try that and see how it goes. I really hope it isnt my opti. lol
Old Nov 17, 2008 | 10:49 AM
bigbirdta94's Avatar
sounds like your opti is gettin ready to take a dump.... i have 94 t/a and mine you to do it when i got on it hard....it never stalled out on me but it def hesitated
Old Nov 17, 2008 | 01:52 PM
x24-7x's Avatar
fixed it. Swapped out the coil and ran perfect. Appreciate all of the help guys!!!
Old Nov 21, 2008 | 07:13 PM
texz's Avatar
Any good (easy) write ups for a coil swap? Sounds like what I am going through right now.
Old Nov 21, 2008 | 11:34 PM
4U 2 NV's Avatar
get a haynes...its a very very very easy swap
Apr 16, 2015 09:57 AM
Jan 23, 2015 01:13 PM
97SSdude
Dec 31, 2014 07:43 PM
Jazsun
Dec 29, 2014 12:14 PM
